Wiring the halos
Old Aug 6, 2007 | 01:20 PM
mcmichael13's Avatar
Default Wiring the halos
Ok so i did a search for this first and didnt find anything that helped... The halos come with a huge harness, has 2 female ends for the right and left light, and a third male end to connect to one of the female ends that the car provides ( i used the passengers side since the battery is on that side). Now the halo has one set of red and black wires for the halo rings, and another set for a third light in the assembly... both just for looks i guess and i will wire them to switches in the cab... now the harness for the lights goes up through a good amount of fuses and boxes and what not, and has two fuses with red wires... where do those red wires connect???
Old Aug 6, 2007 | 01:32 PM
1c1v1c1's Avatar
Default RE: Wiring the halos
wtf my halos just came with a red and black wire on both headlights...and all i did was run the red and black from the passanger to the driver headlight...then i ran the red wires to the switch..and the blacks to a ground...then ran a wire from the battery to the switch...this is my secound pair and they work fine when i wire them like that.....
Old Aug 6, 2007 | 01:56 PM
Ok here are some pictures...
First the front and back of the Halo itself...
[IMG]local://upfiles/7772/C76BB50880A64ADEAFF59F21C10B344F.jpg[/IMG]
[IMG]local://upfiles/7772/E55ABAAC3AAA4FB2B19A568E3BF21B39.jpg[/IMG]
Old Aug 6, 2007 | 01:59 PM
Now for the harness...
Old Aug 6, 2007 | 02:04 PM
if you have AIM, im me at:
Relient k 762
thanks guys, otherwise just post here...
Old Aug 6, 2007 | 03:39 PM
ok guys, new question... i believe i figured out the wiring harness... low beans work and high beams work... my problem now is that before i did this, my blinkers were working... now when i put the lights on, the signal indicator lights come on, but even on the cluster the arrow doesnt even blink... nothing happens... any help?
Mr Mobsta Man
Nov 25, 2007 04:25 PM
Flipside09
Sep 12, 2007 08:54 AM
ProjectGSR
Jan 30, 2007 05:40 PM
maddawg
Jul 21, 2005 12:17 PM
tman
May 7, 2005 08:53 PM
