02 civic starting to burn oil
Old Jan 24, 2008 | 09:30 AM
j00fek's Avatar
Default 02 civic starting to burn oil
just checked all my fluids last night and found that the car has started burning oil somewhat. im suspecting that it burnt 1qt from nov-jan which isn't much but it will become bigger. car has 119K mi... 90% highway miles
im going to be replacing the timing belt this summer and was wondering if changing the valve seals would fix this but it could be the rings as well. or there might be somthing else i could try
thanks
Old Jan 24, 2008 | 11:06 AM
Default RE: 02 civic starting to burn oil
Could the engine possibly be leaking oil rather than burning it?
Old Jan 24, 2008 | 11:35 AM
j00fek's Avatar
no leaks under the car, everything have been checked and is dry.
im going to do a leak down test and check the spark plugs this weekend to see if there is any oil in the plug holes.
moetmo_wet
Oct 10, 2011 09:22 AM
muscobra449
Nov 5, 2009 07:28 AM
oilltd
Jun 10, 2008 04:06 PM
vbcamry
Aug 9, 2006 09:33 PM
