07 Civic EX Battery Discharge
Old Feb 6, 2011 | 04:04 AM
alfred_dr's Avatar
Default 07 Civic EX Battery Discharge
I have a problem with my civic battery. After not using the car for couple of days, the battery discharge, what makes this happen?
Old Feb 6, 2011 | 12:20 PM
Usually this is a worn out or faulty battery. Disconnect the battery while you're not using the car and then if it still doesn't start after you reconnect it, replace battery. If the battery doesn't run down while disconnected, check the car for things that don't turn off. The brake lights, light in the trunk, and aftermarket stereo equipment are common problems.
If you have a stock radio, you will need to enter the security code to make it work again after disconnecting the battery. Read the owner's manual and be sure you know the code before disconnecting.
Old Feb 10, 2011 | 07:09 AM
alfred_dr's Avatar
Thanks. Im going to the dealer to check the battery and see if the car have electrical problem. I appreciate your feedback and use it as a referrence too when the same problem happen again.
me262dave
Oct 14, 2014 05:35 AM
pippo
12
Jun 9, 2012 04:39 PM
Knobmeister
Apr 14, 2012 05:47 AM
lunger
Jul 10, 2011 02:50 PM
addiction2bass
Jul 24, 2006 08:57 PM
