07 Civic less gas milage???
Old Jan 31, 2012 | 08:23 PM
KSwank's Avatar
Default 07 Civic less gas milage???
I've always checked my gas milage at almost every fill up and I typically get around 32-34mpg (going to work, running errands, and what not). Recently I noticed that my car was starting up a little ruff in the mornings. I had my fuel injectors cleaned (thru the intake, not thru the gas tank) to fix the problem. That only seemed to make the problem worse, cuz then the car was getting 5-6mpg less than what I had been getting before.
I took my car to a trusted mechanic and they said that their scanner showed that there was something wrong with the mass air flow sensor and told me that I should take it to an actual Honda dealership. Honda said that their scanner pulled up the same trouble code as the first shop, but claimed that it was actually my valves that needed to be adjusted. After the adjustment I did notice that my car began starting up normal again and my mpg slightly improved, but still was not getting the mpg I was before. Anyone out there experience something similar or maybe have an answer on how to resolve my problem?
Thanks,
Kevin
1995CivicEXBMF
Oct 17, 2009 11:06 PM
ericsd
Jun 13, 2007 08:44 AM
2quickEX
Jun 8, 2006 10:34 PM
alfred medina
Apr 6, 2006 05:16 PM
hank
Nov 3, 2004 07:52 PM
