#1 cylinder not firing!!! help please..
Old Mar 11, 2006 | 04:15 PM
Marty's Avatar
Default RE: #1 cylinder not firing!!! help please..
What is does is when your cyl. fills with pressure the gauge reads it just like a compression tester but this one you have a line hooked to it applying air pressure back into the cyl so that if any thing is leaking past the valves, rings, or out the head gasket it will read it. Kinda like a compression tester but it dont just pull the highest reading and hold the gauge there.
Old Mar 11, 2006 | 06:40 PM
riceburner700's Avatar
and also you will hear a whistling noise coming from the engine (or crank case ventilation unit) if its anything piston/rings related problem
Old Mar 12, 2006 | 09:39 AM
natecivic92's Avatar
Have you tried to put a little oil into the cylinder?That is the easy wet comp test.
mabus013
Apr 1, 2023 04:19 PM
CathleenStargazer
Dec 14, 2013 05:10 AM
srdaniel
Nov 8, 2011 09:02 PM
cjy01
Oct 15, 2011 10:08 PM
cdubscivic
Jun 20, 2004 06:10 PM
