1990 Civic DX Rear Defroster Doesn't Work
Old Dec 14, 2007 | 08:38 AM
kidintheshadows's Avatar
Default 1990 Civic DX Rear Defroster Doesn't Work
Hi guys. Another question.
Since it's winter, defrosting is becoming more frequent but my rear defroster hasn't been working (I don't think it has since I've owned it to be honest). I hit the rear defrost button but no light comes on and I've checked the back connectors but I think they're both connected correctly. I even tried seenig if the fuse was bad but apparently there was no problem, but just to be safe, I switched it with another fuse and still no success. So my question is:
What could be the cause of this problem and where do I go from here?
Old Dec 14, 2007 | 02:12 PM
Default RE: 1990 Civic DX Rear Defroster Doesn't Work
Given that the light does not turn ON when you push the button, the problem is likely the defogger switch itself.
1) Verify that fuse #36 (20A) in the dash fuse box is not blown. If blown, replace.
2) If fuse is fine, then remove and test the defogger switch as described in the picture. Replace switch if any defects are found.
jpj
Nov 23, 2011 01:45 AM
linedpaper
Jul 19, 2011 08:15 AM
2k3civ
Feb 6, 2008 08:24 AM
HaZe89
Aug 7, 2006 08:41 PM
lilol89crx
Jul 29, 2004 06:56 PM
