1993 honda civic. headlight messing up..BAD!
Old Nov 8, 2011 | 05:07 PM
arielyn25's Avatar
Question 1993 honda civic. headlight messing up..BAD!
Ok im going to try to explain this as clear as possible so i can hopefully get a helpful answer..
As i stated in the title, i have a 1993 honda civic EX and ill go to turn my lights on and put them on highbeams. they work just fine but then i go and put them back to lowbeams and sometimes (usually most the time) they will cut completely off and just leave me with my marker lights. This only happens when i switch my lights from high to low and it also happens, very rarely, when i just have my lowbeams on they seem to flicker on and off. I dont know whether its a short in the wires, a fuse or something totally different. if anybody could give me an answer to whats exactly happening..that'd be greatly appreciated!
Thank you,
Ariel
Old Nov 8, 2011 | 09:18 PM
droopy128's Avatar
Try change out the light switch control unit at the steering column.
Old Nov 9, 2011 | 08:25 AM
Ed Fisher's Avatar
Default headlight beam on low intermittent
+1 from the above post. The combination switch is dirty. You can remove the switch, disassemble it and clean it, and reinstall but it is not for the novice. Best bet, get a switch and a manual on how to install.
Ed Fisher
Dallas, Tx
Old May 8, 2012 | 10:25 AM
ImARyDer's Avatar
I was wandering the same question but i was told the headlight switch turn signal part needed to get replaced , is that a yes is what i am asking also?
Old May 8, 2012 | 11:04 AM
It's built together, the light switch and the turn signal lever.
Old Jun 20, 2012 | 10:37 PM
ImARyDer's Avatar
Mines do not work at all only on high beam. was told the headlight switch signal. Which one should i replace or both come together?
Old Jun 21, 2012 | 04:23 AM
There is a writeup in the DIY section on how to clean that combination switch. I'd recommend trying to clean first, even if you're a novice. It's a good learning experience at least. Plus if it works, saves you cash.
Old Mar 14, 2013 | 05:24 PM
ImARyDer's Avatar
Recently, i noticed that my regular beam lights are working properly even with the high beams. Only thing is still my guage cluster lights are not.
Old Mar 14, 2013 | 07:13 PM
If all the lights on the outside of the car work but not the cluster lights---
* Bad dimmer control.
* Blown fuse (only 1996 and later models, 1995 and earlier has the cluster on the same fuse as the tail / marker lights).
* Every single bulb burnt out. Consider this if you just acquired the car. Driving for years at full brightness will burn them out.
Old Mar 15, 2013 | 06:22 AM
Ed Fisher's Avatar
Default No gauge lights
+1 for MK's reply. Oftentimes just wiggling/rotating the dimmer control, located to the left of the steering column, will reinstate the dash lights. The potentiometer gets dirty/dead spot and has to be actuated the get rid of the gunk. Worked for me in several cars through the years, including two Civics.
Good luck, let us know.
Ed Fisher
Dallas, Tx
octodigitus
Aug 8, 2011 07:42 PM
drpepper
May 4, 2011 07:04 PM
klipschfan4life
Jul 16, 2007 03:48 AM
Remmy
Dec 22, 2005 09:58 PM
