1995 Civic Hatchback VX Lean burn stutter
Old Apr 11, 2012 | 07:26 AM
TroyStevens's Avatar
I was having this problem and I believe I have found a fix for it. I joined another forum group called ECOMODDER, these guy's are really into the VX lean burn civics. I found through them that one very important thing to do is make sure that the exhaust manifold is well grounded!! This 5 wire O2 sensor is very sensitive to good ground!! I made a ground strap out of copper braided strap that connects the manifold directly to the nearby body ground that comes off the front of the head. I also cleaned and de-rusted all of the contact points including the area under the O2 sensor. Since doing this I've been able to get the car to pass Ca. Smog test and it now runs great, no hesitation or any other problems.
Old Apr 11, 2012 | 02:50 PM
seanrob's Avatar
Yeah I've been lurking around on ecomodder too, along with gassavers.
hmm, I have been thinking of cleaning all the grounds in the engine bay since some of them really look corroded. Cleaning the threads around the o2 sensor and putting that extra ground is a good idea though. thanks for the input, I'll post what I find.
Old Apr 11, 2012 | 03:55 PM
That's a great tip. Makes sense that the typically rusty manifold can lose its ground. I wouldn't have thought of checking that.
Old Apr 11, 2012 | 05:21 PM
Kendaddy126's Avatar
Originally Posted by seanrob
So I've delt with it for a while, but I'm going to take some time and fix it. When I unplugged it, it ran fine with a CEL but I don't think it was going into lean burn mode due to no o2 sensor signal. I'm planing on cleaning my EGR ports either way, so I'll let you know if that helps. I have had a CEL for codes 41 and 48. I took a quick look at my wiring and it seems to be good, but I would like to test it to make sure. I'm not sure what o2 sensor I have either. It says l1h1 japan with 1624 on the socket part. I don't think it's OEM but can any one identify what o2 sensor it is?
Also, does anyone have a known good o2 sensor around the lancaster, PA area I could try!?
Let me know how it turns out. thanks
Old Apr 12, 2012 | 07:39 AM
One other thing I realized when I replaced the blown head gasket that the original exhaust manifold gasket was a steel gasket. The one that replaced it was a fiber composition thus reducing the ground path to the manifold. That's why I added the ground strap directly to the manifold.
Old Apr 12, 2012 | 09:18 AM
phillip lizotte's Avatar
this is why i love this forum.....im gonna do that just in case.you can never have enough grounding.it affects soo much.
SteveWeb
Apr 13, 2012 04:24 AM
cenzi
Jul 12, 2011 08:31 AM
tman2
Nov 8, 2008 11:55 AM
TmAc7013
Aug 10, 2008 07:18 PM
Motor35
Mar 25, 2007 02:12 AM
