1998 Honda Civic Fuel Filter
Old Apr 25, 2011 | 09:29 PM
danielwd's Avatar
Default 1998 Honda Civic Fuel Filter
Goodness, gracious, who would have thought it would be such a pain in the **** to change out a fuel filter. I've done several - one on a Ford Ranger - that took a whole 10 minutes. I spent the whole evening on my Honda Civic's fuel filter and I still don't have it done.
Does anyone know if the bottom fuel line (from fuel tank) needs a washer? I know the top line that feeds the fuel rail has 2 washers, but the new filter I bought came with a little washer for the bottom line. I went ahead and used it although I didn't notice an old one when I took off my old fuel filter.
Also I have been trying to tighten down the bottom line's hex nut with no sucess! I am still getting leakage and fear to try tightening anymore without a flare-nut wrench. The regular wrench has already rouded off one corner of the nut and I fear more damage.
How tight does that nut need to be anyways? I cant stop the leakage? I wonder if by using that washer on the incoming fuel line is causing the leakage? Any help would be appreciated!
Old Apr 26, 2011 | 03:41 AM
The bottom line from the pump is a flare fitting. Don't use a washer there. It's a tapered metal on metal seal directly between the end of the line and the fitting on the filter. Always use a tubing wrench (flare nut wrench) on the nut.
Edit: It could also possibly be a beaded o-ring seal like an A/C line. Those use an o-ring not a copper washer. The nut doesn't need to be excessively tight.
Old Apr 26, 2011 | 04:23 AM
Just don't end up stripping the nut like I did. I had mine cross threaded and it ruined both the new filter and the line.
Old Apr 26, 2011 | 06:23 AM
danielwd's Avatar
So to review, basically there should be no washer on that bottom line.
Thanks for your input. When I get home I will take it back apart and try again without the washer. Of course, first things first - I am going to find me a flare nut wrench.
Thanks. I'll report back.
danielwd
Sep 14, 2011 07:18 PM
tomp
Jun 30, 2011 07:48 PM
Hailchristian
Jun 23, 2008 12:49 AM
tl12356
Jun 5, 2008 06:38 AM
seriously_furious
Aug 14, 2006 08:49 PM
