1998 transmission issue
Old Jan 5, 2016 | 06:31 PM
sdbrevik's Avatar
Default 1998 transmission issue
Hello all, this is my first post. I have a 1998 Civic with an auto tranny and I can drive down the road and all the sudden it is like the transmission disappeared. it will rev but it is as if I am in neutral. I can take the 7.5 amp fuse out for 10 seconds and get it in limp mode and drove it home. I have tested the shift solenoid and the lock up solenoid and they are good, the last thing I did was replace the ECU. any other ideas?
Old Jan 9, 2016 | 05:18 PM
Flowmaster23's Avatar
Try changing the transmission fluid. Fill.....drive around for a bit, let it shift through all the gears. Then drain again. And do this process 3 times. You could probably just do it 2 times but 3 is more effective. And try using a sythethic oil. Thats all i can think of.. Last resort is pick and pull tranny. But once you do the process above or if you do it. Change your trans fluid sooner then whats recommend.
mudhenFUF
Jan 16, 2023 08:43 PM
musky
Mar 23, 2015 05:40 AM
swh95
Sep 1, 2009 08:29 AM
jonnyboy3467
Apr 20, 2009 08:31 PM
prissy
Jul 20, 2007 10:08 PM
