2000 EX Will Not Turn Over!
Old Mar 1, 2012 | 11:37 AM
BrownRice's Avatar
Default 2000 EX Will Not Turn Over!
Okay, here is the whole damn story. My wife told me she thought she saw some white/gray smoke coming from the front passenger side of the hood. I took a look and found nothing. But on a gut hunch I turned the car on and let it run for about 20 min when I noticed the smoke. Well it seems the fan stopped working, and that caused the radiator to crack at the top. And the fluid leaked down and burned off on the catch. Well I was going to get it fixed this weekend BUT the car stopped working last night. She told me that the car just stopped running. All the lights are on and there was no smoke, no bang, no thumping, or anything. Just off. The car has not turned over since. Revs and all the gears turn but never turns over.
Ideas? Questions?
Old Mar 1, 2012 | 06:14 PM
90 Civic's Avatar
Your last sentence confused me. If it doesn't turn over how does it rev? Other than that do you mean the engine is froze or won't turn over with the key? does it crank or is there nothing when you turn the key?
Third my guess is some wiring burned have you checked any wiring or the harness where you saw smoke. The old saying where there is smoke there is fire.
Old Mar 4, 2012 | 02:12 PM
BrownRice's Avatar
UPDATE
I changed out the rotor, cap, wires, and plugs. Still only cranks. I pulled the wires out and throw a plug in each and not one spark from any of them. WTH is going on?
90 Civic It cranks but will not turn over. The smoke was steam from the antifreeze burning of on the hot motor.
Old Mar 5, 2012 | 03:45 AM
BrownRice's Avatar
And the oil light comes on if I leave the key in the cranked position after about 45-60 seconds.
Old Mar 5, 2012 | 04:23 PM
BrownRice's Avatar
The code reader came up with no codes. WTF?!?!?
Old Mar 5, 2012 | 06:18 PM
droopy128's Avatar
Mostly likely it is your distributor
Old Mar 6, 2012 | 03:07 AM
BrownRice's Avatar
okay that's next then. Thanks
Old Mar 6, 2012 | 04:56 AM
If she overheated it and kept driving until it would go no more, the engine is likely toast. Check the compression.
wchan3
Jul 19, 2012 01:37 PM
pascal11110
Jul 17, 2011 05:20 PM
drumforever
May 28, 2009 06:18 AM
lasombra
15
May 19, 2009 10:55 AM
jeffskw
Oct 3, 2008 03:58 PM
