2000 HONDA CIVIC SI
Old Apr 14, 2006 | 01:44 AM
nivles's Avatar
Default 2000 HONDA CIVIC SI
I bought a short shifter for my civic. I had my mecanic change it because I didn't know how. Now when I change gears the shifter is stiff and hard to move. Is this normal?
Old Apr 14, 2006 | 03:05 AM
nightrider46's Avatar
Default RE: 2000 HONDA CIVIC SI
no it's not normal, the cables had to be lubed up, well a couple of parts had to be lubed
Old Apr 14, 2006 | 08:08 AM
importcivicus's Avatar
is your shifter cable or rod moved.
U placed this in the wrong section....
Old Apr 14, 2006 | 10:51 AM
honda97's Avatar
What kinda short throw shifter did you buy? Cuz I had the same problem. Whats happening is the bottom of your shifter is rubbing on your exhaust. Or at least thats what mine was doing. Sometimes you can fix it by grinding off the counter weights.
Old Apr 14, 2006 | 01:07 PM
nivles's Avatar
I bought it on Ebay 96-00 HONDA CIVIC BILLET SHORT SHIFTER. I don't know if it's cable or rod moved. How do I know if it's placed correctly? How can I lube it?
Old Apr 15, 2006 | 02:35 PM
nivles's Avatar
anybody?
Old Apr 16, 2006 | 09:40 PM
nivles's Avatar
Can I do anything about now?
Old Apr 17, 2006 | 03:53 PM
I think u might have to start the whole thing over again, cuz u might have to lube up the new shifter and slide on the shifter pivot hardware.
Here is a link step by step and what to lube up.
http://importnut.net/shifter.htm
Old Apr 17, 2006 | 09:26 PM
sacicons's Avatar
Its going to be harder to shift, because you are doing the same amount of work as before, but with less movement, so you have to work harder to get it done as you have less leverage. But from the sound of it, the mechanic tightened the lower pivot bolt on the shifter too much, and if you loosen that up and use a little locktight or double-nut it so it doesnt wiggle off, then it should take care of the stiffness.
Oh, and theres no shift cables on a 2000 Si.
turnup_jermmms
Nov 15, 2012 05:31 AM
turnup_jermmms
Aug 14, 2012 05:47 PM
mike.stribling
Jul 13, 2010 05:29 PM
Schimmel03
Feb 12, 2007 09:36 AM
BRIAN05
Jan 22, 2007 06:57 AM
