2003 Civic brake light - weird problem
Old Feb 2, 2010 | 10:26 AM
fourtwenty's Avatar
Default 2003 Civic brake light - weird problem
My wife has a 2003 Honda Civic 4-door. The drivers side brake light does not illuminate when you press the brake pedal. The window and passenger side brake lights do illuminate.
Now when you use the remote entry lock/unlock it will flash. If you start the car remotely the lamp also illuminates, but as soon as put the key in the ignition it shuts off.
The lamp itself is fine, it will work fine on the other side.
I'm not at all familiar with these vehicles but I do have lots of experience working on other cars.
It seems like there must be 2 different paths to the lamp, one via where the remote starter is tied in, and another via the brake pedal switch.
Any suggestions would be appreciated.
Old Feb 2, 2010 | 10:31 AM
I think the bulb is a dual filament lamp. Which light isn't working? The tail light filament or the actual brake light filament? It sounds like the tail light filament is working. That's the one that flashes when you use the keyless entry. The brake light is the one thats brighter and activated by the pedal.
Did the problem start when you got the remote start installed or did it just start recently?
Old Feb 2, 2010 | 10:39 AM
The brake light bulb receptacle gets power from the Wht/Blk wire and ground from the Blk wire. Use a multimeter to check whether the receptacle has a voltage or ground problem.
Old Feb 2, 2010 | 10:59 AM
This usually happens when the shell of the bulb is not grounded, because the socket is corroded, etc. Then there is crosstalk between the brake light and the tail light circuits.
Old Feb 2, 2010 | 11:19 AM
fourtwenty's Avatar
Thanks for the suggestions guys but the lamp I removed, which was the factory original, is a single filament which leads me to believe it is a wiring issue somewhere since the lamp does work under certain conditions.
Old Feb 2, 2010 | 11:20 AM
In that case I'd definitely recommend checking the voltage like RonJ said. If there's a voltage irregularity, check the socket itself for any corrosion that might be causing problems.
Old Feb 2, 2010 | 11:21 AM
fourtwenty's Avatar
Now that I see this, I am wondering if I removed the right lamp because the symptom I am getting can't possibly happen if it is wired like this. I will double check tonight.
Old Feb 5, 2010 | 05:10 AM
fourtwenty's Avatar
So it turns out I pulled the wrong lamp. Thanks for the help guys.
Highlighter
Jul 14, 2013 04:27 AM
juniorbiscuit
Oct 15, 2010 12:24 PM
technomaniac99
May 10, 2010 08:12 PM
gunaa
Oct 22, 2009 11:36 AM
315 Customs
16
Apr 12, 2009 08:26 AM
