2003 civic.need help before winter!
If you're talking about the interior fan not working, usually it is the transistor.
Check if power is reaching the motor first though. Power on both wires to the motor is almost certainly a bad transistor. Power across the motor (one wire live, other one grounded) is a bad motor. Both wires at zero volts check the fuse and relay under the hood. Do these tests with the key on and the switch at high speed.
jeff740
Jul 26, 2009 07:45 AM
csar
May 24, 2009 06:33 PM
TurboShiro300zx
Jul 19, 2007 06:17 PM
