2004 ecu issue
Old Apr 23, 2020 | 11:34 AM
Skeener51's Avatar
Default 2004 ecu issue
Just got car back from garage after 2200$ worth of work. New top end, altenator, power steering pump and camshaft position sensor. Drove 5 miles and check engine light came on and engine lost power. At 2500 rpm it feels like hitting rev limiter. Please help me before I shoot this car.
Old Apr 24, 2020 | 02:33 PM
What's the code for? I would take it back to the shop that worked on it, too.
Old Apr 27, 2020 | 04:39 AM
Skeener51's Avatar
Default Ecu help, please before I shoot this car
After check engine light came on I limped the car to auto zone and used their obd to pull codes. It said camshaft position sensor intermittent. Problem is the sensor is brand new. That was the last repair the shop did and he said basically there is nothing else he can do and told me to take it to dealership. I cringe at that thought. I'm totally at a loss. Anyone want a civic cheap? Lol
Old Apr 27, 2020 | 04:47 AM
Skeener51's Avatar
I cranked the car this weekend and it purred like a kitten. Let it idle for 30-45 minutes. No check engine light, no problems. Then I drove it for about 4 miles and light came on and went into limp mode. Seems to only have issue when load is applied to engine. When it was idling I would raise rpms occasionally to 3500-4000 and no troubles.
Old Apr 30, 2020 | 07:49 AM
Skeener51's Avatar
Default Camshaft position sensor code keeps coming up after replacing
2004 civic lx, new top end, timing belt, altenator, water pump, battery and new camshaft position sensor...$2200. Drove 5 miles and cel comes on and goes into limp mode. Pulled code and says camshaft position sensor intermittent or faulty. It was just replaced. Also replaced same sensor less than a year ago. Please help me. $2200 repair and can't get 5 miles out of it. I'm at a loss. Any help would greatly be appreciated
Jhaycue
Jun 10, 2020 06:03 PM
MelloHonda2001
Mar 30, 2011 07:42 AM
s143ad
Aug 29, 2008 09:24 AM
intense_gravity
Oct 21, 2006 12:57 PM
fast97
Jan 8, 2005 08:55 PM
