Loss of power, rpm rev, jerking shift. Help!
Old Mar 30, 2011 | 05:55 AM
MelloHonda2001's Avatar
Default Loss of power, rpm rev, jerking shift. Help!
2001 Honda Civic LX
Check engine light on, loss of 90% power, high rpm rev into a jerking shift. This has happened a couple of times and each time i turn car off and wait about an hour and start it again and it runs fine. I took it in to a dealership the first time and they said it was an 'intermittent failure' and reset check engine light. Explanation? How do I stop this from happening again?!
Old Mar 30, 2011 | 06:35 AM
Did they tell you which code was set? Whenever the CEL comes on, there is a numeric code for what the ECU sees as an abnormal situation (e.g. sensor readings that don't make sense, suggesting a faulty sensor). The code is read out with a "scanning" device.
Old Mar 30, 2011 | 07:42 AM
From the invoice:
'Verified check engine light on and found DTC P1361 TDC sensor circuit'
ColumbusAdams
Mar 26, 2012 12:33 PM
grove
Aug 25, 2008 04:58 AM
saninca
Aug 4, 2008 08:24 PM
xwhitephishx
Mar 23, 2008 11:33 AM
spencer1087
Mar 25, 2007 07:49 PM
