Loss of power, and RPM and speed-o needles bouncing??
Old Mar 24, 2012 | 05:17 PM
ColumbusAdams's Avatar
Exclamation Loss of power, and RPM and speed-o needles bouncing??
I have a 1997 civic ex 4cyl V-Tech 5speed manual, and just recently it started acting funny. While driving(in no specific gear) the RPM gauge starts bouncing then just falls, also notice a severe loss of power. Sometimes it seems that if I gun it I kind of comes out of it and the gauge starts working again.? Wandering if it alternator issue, fuel issue, some other electrical issue. Just weird because of the loss of power. The engine and transmission are in great shape...
Old Mar 24, 2012 | 05:26 PM
If it's only the tachometer doing that, it could be the ICM. If the speedometer also drops to zero even though the car is still moving, you are probably losing electrical power. Is the check engine light coming on?
Old Mar 25, 2012 | 06:55 AM
Default Check engine light
No, the check engine light isnt on. It's weird, because the radio will shut off and the tachometer will drop to nothing and a loss of power but car still runs.?
Old Mar 26, 2012 | 12:33 PM
Turtlegrip's Avatar
Check connections to battery-alternator, fuse box-engine, grounds. Check connections to cluster too. Alternator can go bad and just barely keep the car running, just not running good. When the car is running disconnect the battery negative, if the car dies you probably need a new alternator. If you can check off the power system then maybe take a look at fuel line, fuel filter, fuel pump but that does not seems likely to be the issue to me. If all else fails check the engine/dash harness and possibly replace the whole thing or bad parts.
Evans058
Aug 1, 2012 07:32 PM
casey42005
May 21, 2010 10:48 AM
xwhitephishx
Mar 23, 2008 11:33 AM
spencer1087
Mar 25, 2007 07:49 PM
AnakinKenobe
Feb 18, 2005 10:38 PM
