2007 civic trans acting weird when cold
Old Feb 4, 2011 | 06:05 AM
eastexsteve's Avatar
Default 2007 civic trans acting weird when cold
My civic has about 65k miles. Not ever driven hard. Trans flush at about 45k. When cold at idle, engine rumbles in every gear except park and drive. It's like something in the trans is trying to bind up. When warm, it goes away, but still does it a bit in reverse.
Any ideas?
Old Feb 4, 2011 | 10:37 AM
Newfiedan's Avatar
Dirty idle air control valve or vac leak can cause it. I would lean towards vac leak though as it get better when warm. Does it get rough when you depress the brake pedal when cold/hot as well, try this when i park as well.
Old Feb 4, 2011 | 04:19 PM
When cold, it idles idles rough in reverse and neutral. Idles very smooth in park and drive.
When warm, it idles rough in reverse. Idles very smooth in drive, neutral, and park.
I will check for a vacuum leak though. But, if it is a vacuum leak, why would it idle smooth in drive, and rough in reverse?
teknicalissue
Jul 23, 2010 05:42 AM
FlipHKD720
Feb 2, 2008 06:59 PM
02blackex
Mar 27, 2007 12:14 PM
windcalmer
Jan 7, 2007 04:24 PM
