30,000 maint.
Old May 25, 2009 | 10:35 AM
gooberguy's Avatar
Default 30,000 maint.
in the honda manual for my car, it says to have a maintence done by a lisenced honda mechanic at 30,000 miles. when i called my dealer about it, they told me it would cost ~500 dollars. i dont have that kind of money. im at about 35,000 now (i know terrible) and i do oil changes when needed. i dont remember what the mechanic told me they do in this "500 dollars" service, but i was wondering if anyone here did.
i feel like my car is slowly dieing on me, as it does not feel as quirky as it did when i first bought it, acceleration is slow/delayed and i just feel like the the car overall is bogged down.
Old May 26, 2009 | 09:46 AM
The manual says what to do at each mileage. Technically you can do it yourself and still keep the warranty in force, if you had done it on time.
Your poor performance may be a clogged air filter or worn out spark plugs, I think both of those are due at 30,000.
Old May 30, 2009 | 05:50 AM
gooberguy's Avatar
i checked it out and it seemed like my tranny fluid was low, which was causing the "hitchy" acceleration also i clean my air intake regularly, (i have a short ram intake) and i haven't gone into replacing the spark plugs, is that a undertaking? or naw
Old May 30, 2009 | 04:24 PM
NewToImportPower's Avatar
Post Depending on model...
1.3L hybrid
Maintenance Items 30,000
Air Filter Element Replace
Body and Frame Inspect
Brake Hose/Line Inspect
Brakes and Traction Control Inspect
Cabin Air Filter Replace
Constant Velocity Joint Boot Inspect
Coolant
Doors, Hood and Trunk Lubricate
Drive Belt Inspect
Engine Oil Replace
Exhaust System Inspect
Fluid - A/T Replace
Fluid - M/T
Fluids Inspect
Fuel Supply Line Inspect
Idle Speed
Lighting and Horns Inspect
Oil Filter, Engine Replace
Parking Brake System Inspect
Spark Plug
Steering and Suspension Inspect
Tires Rotate
Valve Clearance
1.7L CNG
Coolant
Drive Belt Inspect
Engine Oil Replace
Fluid - A/T
Fluids Inspect
Fuel Filter Replace
Idle Speed
Spark Plug Inspect
Timing Belt
Tires Rotate
Valve Clearance Inspect/Adjust
Water Pump
1.7 SOHC
Coolant
Drive Belt Inspect
Engine Oil Replace
Fluid - A/T
Fluid - M/T
Fluids Inspect
Idle Speed
Spark Plug
Timing Belt
Tires Rotate
Valve Clearance
Water Pump
straight from alldata ...hope this helps...
Old May 30, 2009 | 04:30 PM
^^ good stuff. It shows timing belt for 30,000... that's probably "Inspect/clean timing belt". You normally need that replaced every 90,000 miles or so. Or you could simply call Honda, ask them what services are performed at 30,000, and then take it upon yourself to do it.
I always thought that a warranty would be voided if you did the services yourself, and not a license/certified mechanic. But I have never owned a factory warranted car, so I wouldn't really know.
domestic disturbance
Mar 3, 2007 04:06 PM
kinosh
Feb 6, 2007 09:25 PM
RA7325
Jan 15, 2007 03:17 AM
My04Civic
Jul 17, 2006 08:39 AM
wookmaster
Apr 29, 2005 01:31 AM
