6hrs 15minutes till rain I need your HELP.
Old Nov 1, 2006 | 11:47 AM
DanH's Avatar
Default 6hrs 15minutes till rain I need your HELP.
Hey all,
00' Civic HX. Drivers side window is somehow off track. When I try to roll the window up it gets stuck because it's on the outside of the rubber by the drivers side mirror. I go to lunch at 1:50pm and return at 2:50. Any advice on how to get this fixed? Anyone in the NW area know where I can get the door seperator eg Schucks etc..? Thanks for your input and keep your fingers crossed for no rain.
Dan.
Old Nov 1, 2006 | 11:57 AM
Default RE: 6hrs 15minutes till rain I need your HELP.
It's not that hard man, you just gotta pull the door panel off. There should be a screw in the little cubby on the door, one by the door handle, and maybe one on the bottom of the door panel (don't remember for sure). Make sure you pull out the power window stuff (if you have it) and disconnect the plugs so that you don't rip the wires out of the car. Then just give the panel a good yank and the clips should pop out. They're a pain in the ***, just give them hell and try not to break TOO many of them
Once that is off it's a walk in the park, completely self explanitory. Good luck!
Old Nov 1, 2006 | 12:03 PM
DanH's Avatar
Cool, here's hoping.
Old Nov 1, 2006 | 02:29 PM
TheMoogly's Avatar
NW huh... I am downtown portland and I am preparing for the storm as well! Looks to be a bad one until saturday!
Old Nov 1, 2006 | 03:30 PM
D16Punk's Avatar
I had the same problem about a year ago when I first got my 98 hx. Took off the door panel and did just what Forty said. Hope all worked out for you. I haven't had the problem since I've fixed it.
Chandrella Abbott
Dec 19, 2011 03:40 AM
curlybandit
Mar 14, 2008 06:40 AM
Methu969
Feb 19, 2007 01:04 PM
