88 civic engine or electrical Problem
Old Jul 18, 2009 | 06:15 PM
blue88civic's Avatar
Default 88 civic engine or electrical Problem
I bought an 88 civic for $400. It wasn't running because the timing belt broke.
I Have now replaced the head and got it all together. The Car runs but will not exceed 3500 rpm when accelerating.
Now I tried some trouble shooting myself and discovered when i disconnect the ground it revs up fine. But then all the lights flicker.
Can anyone help me?
Old Jul 20, 2009 | 07:57 PM
bump bump
Old Jul 20, 2009 | 08:01 PM
What ground did you disconnect? Is the LED on the ECU under the front passenger carpet blinking any CEL codes? Are any dash warning lights on?
Old Jul 21, 2009 | 05:44 AM
No everything seems to be fine, so I'm wondering if it is an ecu problem.
Old Jul 21, 2009 | 06:55 AM
Old Jul 21, 2009 | 05:19 PM
Valve cover to the body
Old Jul 21, 2009 | 05:42 PM
I would recommend that you thoroughly clean and tighten all of the main ground wire connections under the hood. Use sandpaper to expose clean metal and to ensure complete metal-to-metal contact.
Old Jul 23, 2009 | 07:21 PM
Thanks man ill be trying that on Saturday.
Old Jul 25, 2009 | 02:42 PM
Thanks for the suggestion, It was a timing issue and is has been solved the motor now runs strong.
Thanks for the help guys.
Old Jul 25, 2009 | 03:18 PM
Glad that you found the fix. Was the mechanical or ignition timing off?
goliath
May 1, 2010 08:40 PM
imjrk
Jun 11, 2008 11:02 AM
wjelmer
Nov 3, 2006 10:19 AM
Kuttooz
May 5, 2006 03:18 PM
rick90yj
Aug 14, 2005 08:08 AM
