90 civic cluster swap "blue connector?"
Old Nov 23, 2007 | 08:58 AM
ddavis's Avatar
Default 90 civic cluster swap "blue connector?"
Hey guys,
I just swapped the non-tach cluster from my 90 hatch with a tach having cluster from a 91 si sedan.
My question concerns the number of connectors. My 90 hatch cluster had 3 connectors plugged into it, the 2 normal "white" connectors and 1 smaller "blue" connector. The 91 si cluster just had slots for the 2 white connectors. I plugged them in, left the blue one hanging and everything seems to be working fine.
What is the blue connector for?
Old Nov 23, 2007 | 09:02 AM
my94civic's Avatar
Default RE: 90 civic cluster swap "blue connector?"
theres another thread that is on here from not so long ago and from what i remember it is from cruise control though i may be wrong, have a search
Old Nov 23, 2007 | 09:08 AM
ddavis's Avatar
Yes I saw that post
The thing is my 90 hatch did not have cruise control. It is the standard nothing fancy version.
Old Nov 23, 2007 | 09:11 AM
my94civic's Avatar
yeh i believe they all have the same wiring or similar wiring loom, as mine as the wiring for front fog but doesnt have them standard
Old Nov 23, 2007 | 01:12 PM
As you say, the '90 Civic gauge assembly has three rear connectors: A (A1-A8), B (B1-B12), and C (C1-C5) (picture 1). If the C connector is the blue one you mention, then it controls the Low Fuel Warning Light (see terminal C3 in the circuit diagram of picture 2).
[IMG]local://upfiles/25538/53814639401742D0B36577C26D64E925.jpg[/IMG]
[IMG]local://upfiles/25538/9DB8DAA69FA1484BB9C4E99204DB996B.jpg[/IMG]
Old Nov 24, 2007 | 09:05 AM
my94civic's Avatar
hmm im going to look into that.... see if i can hook something up
Old Nov 27, 2007 | 01:54 PM
ddavis's Avatar
Sorry for the delay on this, Thanksgiving and all...
Thank you RonJ for the pic, my blue connector does look like the c1-c5 connector with some minor differences.
Mine is located in the center of the cluster on a circuit board with 2 wires; One is connected to right speed pulser screw with the other connected to the screw to the right of the speedometer cable. Wish I had a pic I could show you.
It is not an after market conversion, it looks like it was factory installed.
Still a mystery to me.
Old Nov 27, 2007 | 02:16 PM
Just a couple of questions:
1) Regarding the detached blue C connector, does it attach to only one wire (GRN/RED) and is this wire plugged into position C3 of the connector?
2) Is the only light/function that doesn't work in your new gauge assembly the Low Fuel Warning light?
Old Nov 27, 2007 | 04:01 PM
ddavis's Avatar
From what I remember it was a full 5 wire connector now dangling behind my cluster. Neither my old cluster nor the new cluster has low fuel warning indicator.
I will borrow a cam and take a pic of the back tomorrow.
Thank you again for your input.
rossimon13
May 30, 2012 06:20 AM
97_Civic_LX_Matt
Dec 6, 2007 06:12 PM
1998wagonhatch
Aug 15, 2005 03:36 PM
tupi1971
Jul 9, 2005 01:33 PM
millertime17
Jun 26, 2005 09:38 PM
