90 hatchback no fire
Old Apr 16, 2007 | 02:42 PM
90civic_hb1.5L's Avatar
Default 90 hatchback no fire
I am working on a 90 civic hatchback 1.5L for someone. I am not gettting fire to the plugs and fuel injectors are not spitting out fuel. I put a new distributor(td-01u). I don't have the layout for the interior fuses, so I don't know if one is missing or what they are for. If anyone can help with info, I deeply appreciate it. I am also looking for a radiator, right fender and front seats. [:@]
Old Apr 19, 2007 | 01:16 PM
hatch46580's Avatar
Default RE: 90 hatchback no fire
is you comruter working?
Old Apr 19, 2007 | 10:32 PM
b8teen's Avatar
make sure the little red light is blinking on the ecu.
Old Apr 20, 2007 | 07:00 AM
Try this...
Get in the car, and turn the key to the ON position. Your CEL should come on for a second or two, then you'll hear a 'click' as it shuts off. That means your ecu is functioning properly, priming the fuel pump, etc..
If the CEL just stays on, or nothing happens at all, its most likely the Main Relay, which is konwn to go out in the older civics (ef's)
se7ensectoolate
Oct 3, 2005 12:18 AM
FastFwd
Aug 9, 2005 10:21 PM
D16z6
Jul 11, 2005 06:12 AM
OneslowredHB
Apr 27, 2005 09:52 PM
Mad7s
Feb 7, 2005 06:25 PM
