91 Civic 4 speed whining in 4th
Old Nov 10, 2007 | 07:30 PM
paristscp's Avatar
Default 91 Civic 4 speed whining in 4th
The more gas I give it, the louder it gets. It's kind of a not-so-high pitched whine and only happens in 4th gear.
I tried changing the fluid just for kicks, but it's still doing it.
Is this something I should worry about? Do I need to start looking for a replacement to have ready?
Old Nov 11, 2007 | 07:16 AM
paristscp's Avatar
Default RE: 91 Civic 4 speed whining in 4th
Is this sound normal? Come on guys, throw me a bone here.
Old Nov 11, 2007 | 07:54 AM
The information in the picture pertains to the automatic transmission (AT) of 92-95 Civics. I assumed your problem was speed related gear whine. The pictures in my next two posts suggest the potentially faulty AT components. Hope this helps.
[IMG]local://upfiles/25538/F02BEF5156D74430954771FD22C1DC01.jpg[/IMG]
Old Nov 11, 2007 | 07:55 AM
Next picture...
[IMG]local://upfiles/25538/D0655D98934940D6971855AE1B55B010.jpg[/IMG]
Old Nov 11, 2007 | 08:30 AM
Last picture...
(It seems that your AT is on the way out. To save money, you should consider getting a used AT from a salvage yard.)
[IMG]local://upfiles/25538/8736239ACE5947298CF77633136B45EB.jpg[/IMG]
Old Nov 12, 2007 | 05:52 AM
paristscp's Avatar
dude, it's a 4spd
Old Nov 12, 2007 | 05:57 AM
With a manual it's probably just a bearing inside the transmission. You can open it up and replace one or more of the bearings inside, not very expensive. If you keep driving with a bad bearing, eventually the shaft will snap and then you're best off replacing the entire transmission.
Since you're taking the tranny out of the car anyway it might make sense to swap to a used 5-speed. You may need to change the ECU to match too.
Old Nov 12, 2007 | 07:56 AM
ORIGINAL: paristscp
dude, it's a 4spd
Oooops! My bad.
Old Nov 12, 2007 | 08:19 AM
paristscp's Avatar
right on, thanks guys
Think I'll start looking for a 5-speed
Old Nov 13, 2007 | 05:04 PM
paristscp's Avatar
Turns out it's the input shaft bearing
Time to find another gearbox!
investorperson
22
Sep 5, 2011 12:13 PM
eNvYmyCivic
May 23, 2008 06:19 PM
haole
Aug 21, 2007 07:36 AM
Mushroom
Jun 7, 2006 09:51 PM
aap989
Jun 30, 2004 02:03 PM
