help, whining engine
Old Aug 16, 2007 | 04:58 AM
haole's Avatar
Default help, whining engine
My 98 civic DX is making a whining sound. I know the engine isn’t supposed to be so loud. It gets louder with higher RPM’s. It sounds like the transmission, but my dad (who hasn’t heard it) said it could be the power steering? It does kind of sound like the whining sound when you’re low on power steering fluid.
Any help or suggestions are appreciated. I could go check my car if you have any questions about it.
Thanks!
Old Aug 16, 2007 | 06:21 AM
Default RE: help, whining engine
Take the power steering belt off and start it and see if it still whines. Repeat with the air conditioner and alternator if necessary. Should be easy to rule out the transmission because that's on the other end of the engine.
Old Aug 16, 2007 | 02:02 PM
dudes96's Avatar
mine whined like a bastard, i changed the water pump and it no longer does it. just an option.
Old Aug 16, 2007 | 07:38 PM
polo708's Avatar
mine whines... but its supercharged, haha.
power steering IMO but could be a few things.
Old Aug 21, 2007 | 04:51 AM
haole's Avatar
Just got the water pump changed so im thinking its the power steering?
Old Aug 21, 2007 | 07:36 AM
You really should do the test with removing the belts to isolate the problem. Another way to pin down noise under the hood is to listen to each part carefully. There is such a thing as a "mechanics stethoscope." But a cheap alternative is to take a length of rubber hose and put one end to your ear and hold the other end up to suspect parts for pinpoint listening.
investorperson
22
Sep 5, 2011 12:13 PM
eNvYmyCivic
May 23, 2008 06:19 PM
paristscp
Nov 13, 2007 05:04 PM
Mushroom
Jun 7, 2006 09:51 PM
aap989
Jun 30, 2004 02:03 PM
