91 Civic SI stalls at medium rpm (loading, detonating, flooding)
Hi, I am having problems with my 91 civic si. I will start by saying, I just recently completed a motor swap (installed a JDM d15b vtec). Due to money situations I have not been able to buy the proper ECU, conversion harness, and dizzy. Since the motor swap the car has been running rough, I believed it to be because the timing was off a bit, but it has gotten progressively worse. The main issue I am having with the car is it seems to be running very rich, and or loading really bad. Around 3-4k rpm in every gear the car will sputter, jerk, pop and smoke, and nearly die. How I seem to keep the car running it to change gears early and keep the car at very low rpms or very high rpms. The car is smoking very bad, I believe it is gasoline I am seeing. I am not really sure what to do, my car is dying and I need help!
Is the timing right? You have to have both cams in time as well as the sparks.
Check the fuel pressure with a gauge.
Remove spark plugs and inspect if they are all the same black or if the problem is only on some cylinders.
94civichatchback
Nov 14, 2009 08:54 PM
RonJ
Mar 23, 2009 07:57 PM
chase99si
Aug 7, 2008 09:23 PM
suzyscivic
Feb 9, 2006 12:28 AM
2011, 91, 91 civic flooding, civic, d15b vtec in ef, flooding, forum, higher, honda, pm6 with d15b vtec, problem, rpm, si, staling, stalling
