91 ef hatch eletrical
Old Mar 20, 2012 | 09:26 AM
1991hondaguy's Avatar
Default 91 ef hatch eletrical
so my wipers tail lights and dash lights dont work in my 91 ef hatch anyone know what could be wrong with it?
Old Mar 26, 2012 | 08:18 PM
danp1333's Avatar
check all the chasis to engine and engine to battery grounds. bad grounds can manifest
as strange electrical problems. hope this helps
Old Mar 26, 2012 | 08:22 PM
Tail lights and dash lights are on the same fuse. Probe the test points on top of the fuse measure voltage to ground with the light switch on. If one has voltage and one doesn't, the fuse is blown (the most common reason for that is shorted wires at the radio from an improperly installed aftermarket radio). If neither has voltage, it's not getting power from the light switch, take the column covers off and check at the light switch. This is assuming the head lights work. If they don't work either, there is a big main lights fuse in the box under the hood near the battery.
For the wipers, turn the key on, switch on, and listen if the motor runs. Motor running but wipers not moving is naturally a mechanical problem. If the motor doesn't run, go to the fuse and again make sure both test points are live with the key on. If that's OK it could be the switch or the motor, would need to check a diagram to determine what to measure to tell which one.
radbebbins22
Dec 12, 2007 06:39 PM
rico892002
Feb 12, 2006 01:51 PM
redlines4us
Jan 19, 2006 09:42 PM
darknightmr2
Dec 22, 2005 08:26 AM
pkfrdh
Mar 18, 2005 04:11 PM
