92 honda civic, Eletrical Fuel pump problem.
Old Dec 4, 2007 | 09:18 PM
radbebbins22's Avatar
Default 92 honda civic, Eletrical Fuel pump problem.
My Car has been running fine with no problems whatsoever, and one day I came out to start it up and it just wouldn't crank up, and I noticed the check engine light was on. So I just gave up trying to start it, came out the next day and it cranked up. I drove it, parked it, next time I came out to start it, same thing, Check engine light. I replaced the main relay, Tested the fuel pump, and it's fine. After trying to start it , with the ignition on, the check engine light randomly goes off, the relay clicks and the fuel pump starts wizzing, The car will Run fine, and when I turn it off and back on, the check engine light takes only a few seconds to click off, and the fuel pump starts whizzing. But when I try to start it in the morning, the check engine light will not click off. Does this have something to do with the ignition key switch, or the CPU? Any information would be very helpful, Thank's alot!
And one more thing, a couple times the windshield wipers came on when turning the ignition on, and they weren't turned on, I wiggled the key and they stopped.
Old Dec 4, 2007 | 09:27 PM
Default RE: 92 honda civic, Eletrical Fuel pump problem.
You may have a faulty ignition switch. What year and model Civic do you have?
Old Dec 4, 2007 | 09:34 PM
A 92 civic
Old Dec 4, 2007 | 09:43 PM
First, use information at this website to retrieve your CEL code:
http://www.honda-tech.com/zerothread/1901557
Second, the picture tells you how to troubleshoot the ignition switch. Note that you may need to wiggle the key as you mentioned to reveal the potential fault.
[IMG]local://upfiles/25538/496654CA43EF4235A0D4CAC479BAD8CC.jpg[/IMG]
Old Dec 4, 2007 | 09:57 PM
thanks going to check in the morning .
Old Dec 12, 2007 | 05:51 PM
Well, tried to check the CEL number, but the light stays on and doesn't blink, and also the Oil and Temp light are on with the cel.
Old Dec 12, 2007 | 06:05 PM
ORIGINAL: radbebbins22
these lights are normal to be on when u turn ur key on and engine isnt runing. sounds like it to me that u have a short some where just take a look under ur dash at wires anything rigged???(not factory) relay could be goin bad or bad ignition switch.
Old Dec 12, 2007 | 06:39 PM
This outcome with the CEL indicated that the ECU back up system is in effect (see picture). You may need a new ECU.
[IMG]local://upfiles/25538/930536277B46464CA3AC6F9E71400CC2.jpg[/IMG]
1991hondaguy
Mar 26, 2012 08:22 PM
wkhan69
Aug 9, 2009 10:08 AM
jutrumpet42
Dec 24, 2006 11:04 PM
seriously_furious
Aug 14, 2006 08:49 PM
rico892002
Feb 12, 2006 01:51 PM
