Fuel Pump Problem
Hi, when I turn my key into the (II) position, the fuel pump usually gives a whirring sound. However, the pump doesn't "whirr" right away when I turn the car on after it rains. I mean, eventually, if I leave it in the on position for a time it eventually whirrs. I noticed that it ususally does this after it rains, so would it be that there is a connection that is getting moist...or something.
Thanks for your help,
--Joe
--Joe
Wires (for the fuel pump) are run through the cabin (scratch the thing about wires outside the car) so if you have water inside the cabin and the wires are broken the water will interfere with the wires. And i believe that if you have air going through the fuel pump(especially alot of it), it will cause the fuel pump to wear out since gasoline lubricates the internal parts of the fuel pump.
wkhan69
Aug 9, 2009 10:08 AM
radbebbins22
Dec 12, 2007 06:39 PM
