91 integra overheating
Old Mar 8, 2010 | 06:14 PM
did you test to see if the top of rad is hot and bottom is cold??
Old Mar 9, 2010 | 04:35 AM
colby_666's Avatar
No I forgot to but I will when I get home but the thermostat is out if that matters or is that just to check that the radiator is cooling the water so it don't matter, on the 30 mins this morning at 5:30 the car only just started heating up when I has to go into work but at least I made it and didn't overheat
Old Mar 9, 2010 | 04:45 AM
If it overheats only when you're stopped or in slow traffic, and not at highway speed, that is usually because the fan doesn't work.
Old Mar 10, 2010 | 05:09 PM
colby_666's Avatar
ok once i got home today it was just getting to normal running temp, im still running the car with the thermostat out and the top radiator hose was hot and the bottom hose was cooler, i tryed leaving it in park and reving it up to try and overheat it but it didnt overheat, also the fan wasnt on, im not sure at what point the fan is suspposed to come on at but as soon as i shut the car off the fan come and stays on for like 10 mins or something like that so i know it runs fine, does that normal that the fan wont come on til it gets past normal running temp?
Old Mar 10, 2010 | 06:03 PM
I don't know. It is an Integra after all and you're asking this on a Civic forum. I do know that Civics of that era are wired so the fan will never run with the key off, at all. Clearly something is different about your Integra.
kvh
Feb 22, 2008 10:15 AM
domex
Feb 12, 2007 10:24 PM
trebor_2005
May 19, 2006 01:40 AM
sonscivic
Jan 4, 2005 06:16 PM
Civic95Blue
Jul 29, 2004 10:09 PM
