92 civic heat
Old Nov 22, 2008 | 11:23 AM
Dipsetcivic117's Avatar
Default 92 civic heat
so my heat decided to start messing up now that the cold is coming. so i was driving and i put on my heat...i usually hit the button where the arrow is comming from the front of the car...not the one that has the circling arrow...and when i had it like this it would blow out hot air even on the first speed. even when the speed was off i would feel heat coming out.. then one cold *** day i put the speed all the way up and i noticed like a shacking sound...i knew it was the heater blower cuz when i lowered it the noise stopped...now i feel now hot air when on the straight arrow...so now i put it on the circulating one....is my heater motor gonna go soon??
Old Nov 22, 2008 | 11:47 AM
Check whether the blower motor may be clooged with leaves or debris. Removing the glove box will give you access to the blower motor, which should drop down and out after removal of three screws.
Old Nov 22, 2008 | 11:53 AM
iight...whats the easiest way of taking out the glove box..
Old Nov 22, 2008 | 01:51 PM
mundy5's Avatar
if it is anything like mine, the glove box needs to be squeezed on both the left and right sides and it will open right down.
Old Nov 22, 2008 | 02:13 PM
You don't have to do anything to the glove box to remove the motor. It comes out the bottom. It's on the very far right side of the car. Remove the 2-wire plug and 3 screws and lower it out.
When you have the selector on "fresh air" (arrow from the front of the car), driving the car at speed will force some air through the system even without the fan running. When it is on "recirculate", the fan must be running.
Old Nov 24, 2008 | 09:48 AM
yea it use to put it on "fresh air" and i would feel heat coming from the motor and the firewall...but now all of a sudden i only feel cold air..weather or not i have the heat on or off..
tpatru
Oct 8, 2008 08:12 PM
sylver8248
Aug 27, 2008 05:23 PM
mr honda
Jan 29, 2008 11:52 AM
Scavenger32
Jun 29, 2007 09:56 AM
oraphus
Mar 22, 2006 06:11 PM
