Spark plug question
I want to change spark plugs to my ride, but i cant find the right information of what kind of spark plugs do i need, my car its a civic sir 99 b16a2 turboed with a garret t04 , some people told me that get a step colder than the oems and blah blah blah..... Could some help me with this problem? Must consider that i live in mexio city 2200 m over the sea..
Ill appreciate any kind of help thanks a lot !!!!!!!!!!!!!!!!
[QUOTE=Forty04;605707]Talk to whoever tunes the car, they will have the best recommendation.
NGK Two step colder plugs is what I always ran in my boosted setup[/QUOTE
THANKS FOR THAT, BUT WHAT CAN U TELL ME ABOUT THE GAP? MEXICO CITY ITS ALMOST 2200 METERS OVER THE SEA!!!
CAN I USE PLATINUM? OR IRIDIUM SPARK PLUGS?
THANKS FOR YOUR HELP GUYS!!!!!! SEE YOU AROUND......
The turbo of course boosts the pressure of air entering the engine. So the altitude isn't as big a factor as with a non-turbo setup.
I would suggest if your car has been running OK, just replace the plugs with new ones of the same kind you have now. Platinum or iridium lasts longer, but they really don't work any better than fresh conventional ones.
PLat. Irid. do not agree with Hondas, especially when boosted. Avoid them at all costs.
mk is right, your best bet is to pull out the plugs that are in there, and just get four new ones identical to them.
Again, Gap is something you need to discuss with the tuner, as every setup is a bit different. Recommended (stock) Honda gap is .044, however my plugs were always way down around the .032-.034 area.
dml955i
Jun 8, 2005 03:31 PM
