93 civic dx wont start
Old Aug 20, 2009 | 10:51 AM
wjd03's Avatar
Default 93 civic dx wont start
Nice site all..First of all I have checked the starter and the clutch pedal switch. Both are ok. All lights are comming on on the dash as usual. Problem is wont crank at all!
Soliniod is getting juice. I am not sure where else to chech or how to check it...Need help
Old Aug 20, 2009 | 11:14 AM
Is the starter motor getting juice? Check the big wire attached to the starter for battery voltage.
Is this a recent motor swap? If so, did you reconnect the important tranny ground wire?
Old Aug 20, 2009 | 11:19 AM
wjd03's Avatar
Default re
No its not a motor swap or ground problem. I checked all the Low Hanging fruit (lol) but I have to go further on this one. I took starter off and got it checked...good. plenty of juice getting to starter but nothing. I jumped the clutch switch...still nothing
Old Aug 20, 2009 | 11:44 AM
wjd03's Avatar
I was wondering if anyone knows what the small b/w wire comming from the solinoid is and where it is going in the harness. There has to be another relay somewhere else. I can hear the relay on the fuse panel clicking but the starter just wont turn...it is getting full power from the battery
Old Aug 20, 2009 | 11:58 AM
Does the small wire attached to the starter have battery voltage with the key in ON(III)?
Old Aug 20, 2009 | 12:06 PM
wjd03's Avatar
Thanks for helping! Turned the key on nthhing. 0.01 and 0.00
Old Aug 20, 2009 | 12:07 PM
the small b/w wire goes to the ignition its what turns your starter on.
take a screw driver or a good peice of wire and turn key on make sure its in neutral and jump the 2 connections from the starter. does it start??
Old Aug 20, 2009 | 12:11 PM
Now do the same test for the Blu/Blk wire in the connector for the starter safety switch at the top of the clutch pedal. Also test whether the Blk wire has continuity to ground.
Old Aug 20, 2009 | 12:13 PM
wjd03's Avatar
are you talking about the b/w (small wire ) from the plug on the solinoid and the thick 12 volt wire and jump them?
Old Aug 20, 2009 | 12:18 PM
yes jump the big wire going to the starter with the other connection on the starter. you can pull the small wire off jump the big wire to where the small wire was plugged up to
jump the black/white wire from the ignition column to the one of the black/white wire that goes into the starter relay plug (which is located on the left side dash wall)
it should start with key
