93 civic wont start
Old Aug 25, 2007 | 08:39 PM
bolt8192's Avatar
Default 93 civic wont start
I have a 93 civic thatstarts when it wants too! It will turn over, Has spark. I changed the main relay, ignition checks out with test light. When I here the fuel pump car will start. noticed tonight if I turn the key on and let it set for a few minutes I heard the relay and pump come on, also theengine lite goes out and car will start. any ideas
Old Aug 26, 2007 | 12:07 AM
danomatic93's Avatar
June 2010 ROTM
Default RE: 93 civic wont start
Fuel filter? I'm just guessing.
Old Aug 26, 2007 | 04:30 AM
kinosh's Avatar
When you turn the key, do you not hear anything for the first minute or two? Then, without doing anything, you suddenly hear the pump go on? That would be a sign of a bad electrical connection: either the main relay, fuel pump, or somewhere in-between. When you changed the relay, did you get a new one or from a junkyard? If it's a used relay, try re-soldering the connections.
Old Aug 26, 2007 | 06:52 AM
bolt8192's Avatar
sometimes you hear the pump immediatly and the car will start, I noticede last nite if I do nothing for a few minutes when I dont hear the pump then it will come on. The relay is a new one
David_S
Oct 24, 2013 10:06 AM
bmelloh
May 16, 2009 08:01 PM
black99ta
Aug 2, 2005 05:24 AM
Aztec007
Jun 15, 2005 04:06 PM
AndyI
Oct 6, 2004 09:36 AM
