93 Honda Civic- Shifter linkage and bushings
Old Oct 17, 2010 | 08:51 AM
1stHonda's Avatar
Default 93 Honda Civic- Shifter linkage and bushings
Hi Guys-
So If I want to pull out the # 2 shifter rod can I do so by first unscrewing the #3 shifter **** and then just removing the # 27 & 24 bolts? From there does the rod just slide out from the bottom? Or do I need to remove the #14 rod too? I'm worried because it's super rusty and the #24 and 27 bolt won't budge. I was thinking I could cut off the #27 and 24 bolts with a dremel. Pull out the #2 rod, replace the #5 bushings, and then reinstall with new hardware.
Ideas?
http://www.hondaautomotiveparts.com/...y5=SHIFT+LEVER
Old Oct 17, 2010 | 09:54 AM
To replace bushings 5, only the bolt 27 needs to come out. Cut or break it if it's rusted and replace with a new one.
Part 8 is also subject to wear, replacing it requires taking the shaft 2 out of the car by removing flange 9 and the handle 3 so it can come out the bottom.
Old Oct 17, 2010 | 09:18 PM
1stHonda's Avatar
Help! The# 24 nut broke off and now I can't get out the # 27 bolt out. It's completely rusted inside of the #12 sleeve, which is inside of the # 2 shifter. I can still shift, just really sloppy. Should I break or cut off the rest of the #27 bolt off and try to hammer it out?
What should I do?
Is there a chance that I can remove everything that's inside the #2 shifter? I thought it was a sealed cartridge bearing.
I'm worried that if I try to remove anything else it might break. All the nuts and bolts are really rusty.
markuscreek24
Jul 13, 2010 05:59 PM
addiction2bass
Mar 28, 2010 11:34 AM
MrLizard
Aug 21, 2008 01:53 PM
brunborg
Jan 14, 2008 08:38 AM
TrAvIs 05
Jan 15, 2007 05:56 PM
