93 speedometer out of wack
Old Jul 9, 2005 | 04:18 PM
nemethjames1's Avatar
Default 93 speedometer out of wack
i got a 93 ex, and the needle jumps around a little bit, not all the time either... and the speedometer seems to be about 5-10mph off most of the time.....
replaced the speed sensor, whats next?[:-]
Old Jul 9, 2005 | 08:08 PM
tupi1971's Avatar
Default RE: 93 speedometer out of wack
I have a similar problem with a 98 CX, your next step is to check the speedometer. Remove the instrument cluster and pull out the speedometer, with careful disassembly you can reach the mechanical and electronic parts, if there is no evident mechanical failure you probably have an electronic failure. Try a different speedometer or move the mechanicals by hand to see if it jumps around. If when moving mechanicals by hand there is no jumping around you probably have bad electronics and likely need a new speedometer.
Other things to check
Healthy electrical system
Same tire height as original
Old Jul 10, 2005 | 01:10 AM
anyone got a gauge cluster that will fit mine they want to sell?
gas_miser
12
Mar 13, 2009 08:01 AM
BillStuart
Dec 9, 2008 06:33 AM
MHSBaseball
Jul 8, 2007 07:55 AM
xxeddixx
Aug 24, 2006 05:06 PM
AnakinKenobe
Aug 19, 2004 05:44 AM
