'94 Civic DX - Sunroof not working
Old Jul 12, 2012 | 07:43 AM
RoroGuanaco's Avatar
Question '94 Civic DX - Sunroof not working
Any Ideas on how to fix the sunroof on a '94 Civic DX.. I've checked the relay and its good.
Old Jul 12, 2012 | 09:08 AM
ChristianL's Avatar
Is the motor making noise when you hit the button?
Also, do you know how to close the sunroof manually? I never had to do it on our '94, but I thought it was a nice bit of engineering genius.
Old Jul 13, 2012 | 07:05 AM
Well the button doesn't do anything, noise or nothing. And it doesn't have a handle to open manually..
The diagram states that is fuse 14 with 20Amps....
Old Jul 13, 2012 | 09:02 AM
You are 100% sure that this is factory? I have never seen a DX with a factory sunroof. If it is aftermarket, that is why you cannot shut it manually as christian mentioned.
Old Jul 13, 2012 | 10:47 AM
ChristianL's Avatar
I was thinking the same thing.
If it's a factory sunroof, there should be a little circle in the headliner (I think it's near the rearview mirror). If you pop that off, there's a **** in there that can be turned to open and close the sunroof. Our '94 had a special tool that was packed in with the lung wrench and such. It was one of those things that was designed to get it closed just in case.
Otherwise, you'll probably want to pull the headliner to get to the motor and see if current is getting to it. If it is, the motor is probably bad. If it's not, it's possible the switch is bad, or may even just have dirty contacts.
Juans_MX3
Apr 7, 2010 03:38 PM
gunaa
Oct 22, 2009 11:36 AM
mcneesejd
Oct 17, 2007 05:29 AM
rcoursey
Aug 29, 2007 02:33 PM
chrisroug
Oct 2, 2006 11:36 AM
