94 Civic EX Timing Belt
Old Mar 26, 2011 | 10:03 PM
dbrine's Avatar
Default 94 Civic EX Timing Belt
I'm in the process of changing the timing belt but the cam gear doesn't have the word "UP" like all DIY I see? I have the 2 timing mark on each side of the pully put I'm not sure which way is up...?
thanks,
Old Mar 27, 2011 | 04:40 AM
Line up the marks on the sides then take the distributor cap off and note that the rotor points to wire #1 (the plug closest to the timing belt). That is the proper position to use the marks on the sides. If it points to #4, you need to turn the cam 180 degrees.
Old Mar 28, 2011 | 06:50 PM
xbezubzx's Avatar
it might be easier to just pull the #1 spark plug stick a long screw driver into the cylinder and wait until you hit top dead center.. do this while you watch your marks then you'll now which way is up..
smackpower
Jan 13, 2024 01:42 AM
Kyle700
Sep 18, 2014 07:44 PM
pippo
Jan 26, 2010 02:40 PM
vitod
Jul 7, 2005 01:12 PM
JALTAM901
Nov 14, 2004 11:17 AM
