94 EG sedan crv B20B4 wont start
Old Feb 15, 2012 | 02:08 PM
chexmix273's Avatar
Default 94 EG sedan crv B20B4 wont start
parts I've replaced
Distributor cap
Rotor
ecu
Plugs
Wires
checked coil pack
Ignition control module
obd1 so no crank sensor needed
car gets fuel to injectors but im not sure if its going through them so im cleaning them tonight. any ideas at all would be great. thanks in advance
Old Feb 15, 2012 | 03:35 PM
Is the ignition firing strong sparks? Are the cams in time? Are the plug wires in correct sequence?
Old Feb 15, 2012 | 03:53 PM
chexmix273's Avatar
have to put injectors back in to check spark, yes and yes
Old Feb 16, 2012 | 04:48 AM
Has this setup run before or did you just swap it in?
Old Feb 16, 2012 | 09:56 AM
chexmix273's Avatar
no sold my 95 impreza for 1500 and picked this up for 1100.
rotor turns but no spark. mechanic left so i couldnt take out a plug to test it just used a grounded out screwdriver not getting any spark. like i said new cap and rotor and coil pack is good with a brand new ign control. main relay still kicks and ecu is correct for the car. the mechanic went through the wiring and said everything is legit. losing hope daily. need this on the road asap for the new baby
Old Feb 17, 2012 | 04:22 AM
Check that the low voltage wires on the coil get battery voltage both with the key "on" and while cranking. Check for ECU codes.
Old Feb 17, 2012 | 02:39 PM
chexmix273's Avatar
i went all sorts of crazy with a multi meter today. 3 of 4 plug wires didnt even have continuity. didnt even bother with the last. would have checked them sooner if i hadnt been told they were new. every single other piece is good i was just like staring at the engine wondering what else it could be.... wires it is
mentaldis0rder
Sep 18, 2006 09:10 PM
Marty
Jul 14, 2006 07:54 PM
Fiirkan
Jun 14, 2006 10:11 PM
Drakkhen
EK Swaps
12
Feb 12, 2006 11:11 PM
Remmy
Mar 20, 2005 08:09 AM
