95 civic control arm bushing keeps failing
I have a '95 civic dx with 302,000 miles on it, and it runs fine for the most part, but in the last 15 months or so I've had the control arm bushing replaced 4 times, and now it's bad again, it causes me to go ruin front tires in about two weeks, so it gets rather expensive. I've gone to two places and both said they had never seen this problem even once, so I'm hoping someone out there might be able to help. Thanks in advance.
This may be an obvious comment, but a good place to start, did you preload the bushing before tightening it down? If you dont they go pretty quickly because you end up reverse loading them in the normal control arm position.
i say replace the control arms next time to see if it's something else that's causing your premature tire wear.
Your bushings should not be failing this fast. Sounds like your alignment/suspension settings are jacked up.
Is it slammed?
Is it slammed?
ranger5830
Jun 15, 2011 06:06 PM
addiction2bass
Apr 14, 2008 06:28 PM
addiction2bass
Oct 24, 2007 05:07 PM
biocpu
May 1, 2007 05:06 PM
ClayMayTion
Jan 7, 2006 10:35 PM
