96 civic 1.6 no start
Old Aug 23, 2012 | 08:18 AM
veja's Avatar
Default 96 civic 1.6 no start
new icm/ coil, fuel filter/ 40psi, main relay, timing belt good. I have spark and sounds like a misfire when first start...lost
Old Aug 23, 2012 | 09:36 AM
How to the spark plugs look? If you take one spark plug wire off, does the car start and stay on? You might need to pull one, then another (after putting the first one back on) to see if that helps diagnose where the problem is exactly.
Old Aug 23, 2012 | 11:54 AM
Make sure it is actually in time by checking the marks on the cam pulley. Timing belts can skip teeth. Also conduct a compression test-- one dead cylinder makes a D series engine very hard to start.
Old Aug 23, 2012 | 12:32 PM
newman340's Avatar
mine did that last week couldnt figure it out ended up being the fuel pressure regulator maybe give that a shot
David_S
Oct 24, 2013 10:06 AM
honvic
Oct 6, 2013 01:50 AM
pownstarz
Apr 19, 2010 12:30 PM
bmelloh
May 16, 2009 08:01 PM
Ronin Inc
EG Swaps
Jul 10, 2008 06:29 PM
