96 Civic No Start
Old Feb 12, 2010 | 10:07 AM
BradInTexas's Avatar
Default 96 Civic No Start
My son's 96 Civic's battery died on him. He replaced it but all he has are the flashers, no dash indications, no radio, nothing. I had him check the fuse box under the hood and the battery connections, but he can't find anything. He is not a car mechanic. I am but I am 200 miles away. If anyone can think of something that would result in this condition, please reply. I'd like to avoid a trip down there if possible. I believe it has a D16Y7 engine in it if that matters. I recently replaced the ignition coil and module. The car hadn't been giving him any problems before the batter died.
Old Feb 12, 2010 | 10:20 AM
S142JZKillaV10's Avatar
Has he Checked the main batt and ign fuses ??
Old Feb 12, 2010 | 10:32 AM
If all of the hood fuses are fine, then the ignition switch might be bad. Nonetheless, have him first check whether the fuel pump primes for 2 seconds when the key is turned to ON(II) and whether there is bright white spark at the plugs.
Old Feb 12, 2010 | 11:49 AM
Do the headlights work? Check the ground wire from the battery to the frame and the transmission. I would tend to think that this problem happened first and he thought it was simply a dead battery.
David_S
Oct 24, 2013 10:06 AM
honvic
Oct 6, 2013 01:50 AM
pownstarz
Apr 19, 2010 12:30 PM
bmelloh
May 16, 2009 08:01 PM
Ronin Inc
EG Swaps
Jul 10, 2008 06:29 PM
