96 civic Si Canada
Old Aug 20, 2008 | 04:36 AM
nigel_miguel's Avatar
Default 96 civic Si Canada-windshield washer not working
i have 5 speed 96 civic SI (canadian), I noticed yesterday the windshield washer fuild wasn't coming through when I hit the lever. the wipers still work though.
I checked the fuse, (wipers still work), not the problem.
I even tried to hear if the motor was trying to pump the fluid through the nozzles, and I couldn't hear anything.
I think the motor could be gone!!! 1st off, where is the motor? how do i test it?
thanks for you help
Miguel
Old Aug 20, 2008 | 07:31 AM
mcmichael13's Avatar
well if the ek is anything like the eg, the motor is on the reservoir which is in the front drivers side of the engine bay... look for the refill cap and follow that down to the reservoir haha. the motor should be attached to it.
Old Aug 20, 2008 | 07:51 AM
I think you have to take the front bumper off to work on the motor. Test the switch first to be sure it isn't the switch. Then get access to the motor and put a voltmeter across the two terminals. Pull the lever; if you have 12 volts but the motor doesn't run, it is bad.
Old Aug 22, 2008 | 07:56 PM
SilverSedan's Avatar
chances are good its the pump motor. I havn't done one on a honda yet, but most washer pumps are held into the reservoir by a rubber O-ring.
1) unplug wire harness and hose
2) pull out old motor
3) get soaked in washer fluid while jamming new pump back into the hole
4) curse, then reconnect wire harness and hose
5) refill tank
done!
Old Aug 22, 2008 | 08:12 PM
macbeth18288's Avatar
Did you check to see if you're leakin fluid anywhere?
Old Aug 22, 2008 | 08:39 PM
Check that the ground wire of the washer motor is connected, clean, and making good electrical contact.
Aseret_MO
Jun 25, 2008 07:59 PM
oilersfan2200
May 31, 2007 09:35 AM
70sMan
Canada, Over Seas & Elsewhere
Dec 3, 2006 11:50 PM
nigel_miguel
Nov 26, 2006 12:53 AM
06civic
Jan 1, 2006 12:31 AM
