96' Dx D16Y7 Problems "failure to launch"
so i checked the timing its perfect but the compresion is only 30 psi... i tryed the trick were you put oil in the spark hole to seal off the cylinder and it raised pressure to 200 psi. now i just have to wait for a little of the oil to seep out into the piston rings so it has room for ignition... hope it works
christinav09
May 29, 2010 07:59 PM
