96 Ex with aftermarket Fogs
Old Jun 11, 2009 | 07:12 AM
burnindesirez02's Avatar
Default 96 Ex with aftermarket Fogs
I recently bought a 96 Ex that had aftermarket ebay fog lights on it and he hardwired into the taillight fuse..well the fuse keeps blowing and the wiring is horrible onit...i was wondering how hard it is to wire it into its own fuse yet have them still come on with the headlights...or do the 99-2000 Si have their own foglight switch? Thanks
Old Jun 11, 2009 | 09:47 AM
If there's no factory fog light wiring, simplest way to do this is to start at the battery, install an in-line fuse near the battery, then send the power through a new relay under the hood to the fog lights. Wire the coil of the relay in parallel with the stock headlight circuit (low beam) so when you turn the lights on, the relay will pull in and send power to the fog lights through your new wire and fuse from the battery.
Old Jun 12, 2009 | 06:39 AM
alright thanks Mk378...do i just splice the low beam circuit?
Old Jun 12, 2009 | 06:49 AM
will i be better off getting Password JDM foglights over the ones on Ebay? since the guy before me already had the ebay ones in...
Old Jun 12, 2009 | 07:41 AM
Yes go to one of the headlights and splice into the low beam wire and the common wire, route those to the coil of the relay.
If you like the fog lights that are on the car now, no need to replace, just rewire for them.
Old Jun 12, 2009 | 12:35 PM
I wouldn't splice into the low beams. I did, and the fogs served no purpose at all... I am guessing there wasn't enough power being sent to the low beams to power the beams and fogs.
Once I took the fog wiring out of the low beams and pulled extra power from the batterry directly, the fogs were about 3 times brighter and actually made a difference.
Old Jun 12, 2009 | 12:38 PM
The splice into the low beams is just to turn the relay on-- the fogs get power from the battery through the relay. Thus the car's stock wiring is not overloaded as it takes only about 0.1 A to turn on a relay.
roomie92
Jun 28, 2009 07:18 AM
tmac914
May 26, 2007 11:24 AM
hazo vti
Jul 13, 2006 05:59 PM
sy_82_nj
Aug 15, 2005 11:30 AM
LT2004ever
Nov 9, 2004 03:34 PM
