96 LS into 96 Civic HB
Old May 13, 2009 | 01:59 PM
runwitme's Avatar
Default 96 LS into 96 Civic HB
here's the list i got:
96 LS long block with tranny
manifold w/ tb
axle
shifter n shift linkage
disturbutor and alternator and starter
stock headers
ecu
pretty much complete jus missin harness, fuel injector and fuel rail
questions:
1: so i searched a few forums and i believe what i need are 2 mounts from a 99-00 Si . i believe it was the rear tranny and driver side brackets? .. is that correct???
2: not going to run ac so i dont need the ac mount . correct???
3: i can reuse my stock harnes with the exception that i might have to extend some wires .. correct????
4: pretty much everything else jus plug and play? . correct???
and yes i know its been cover billions and trillions and millions(said like drevil . muahaha) times but i jus wanted to make sure i got everything correct before i get the go head .
any input/suggestion would be highly appreciated .. thanks in advance
and if there's a write that anyone know of . plz post link to it
forgot to mention i got a 96 HB DX
Old May 13, 2009 | 02:06 PM
plethoric33's Avatar
You can use your harness. Im not too sure on the mounts, I just have the Hasport B into EK mounts. You dont need the a/c mount if your not going to use it.
Sayajin
Apr 9, 2008 07:35 PM
DanCare_EJ9
Dec 25, 2007 04:34 AM
mr honda
Aug 25, 2007 09:31 PM
sacicons
Mar 30, 2005 11:48 AM
grncivicvtec
Mar 18, 2005 08:23 PM
