97 Civic AC works ONLY at idle
Old Mar 11, 2012 | 05:35 PM
monticellorob's Avatar
Default 97 Civic AC works ONLY at idle
Very strange. Whenever I first start my civic, the air conditioner works. However, after about 5 minutes it no longer cools. Whenever I start a cold engine, I can see the AC clutch spinning. However, as the engine warms up, after about 5 minutes, the clutch disengages. At the low pressure port, without the AC on, the static pressure is around 80.
Someone help??
Old Mar 12, 2012 | 05:14 AM
Compressor not engaging when hot is usually because the clutch gap is too wide. Remove the clutch plate and take some of the shim washers out. You can do that with the system still charged.
Mrclark
Jan 19, 2012 06:59 PM
Clean_Civic_98
Sep 23, 2010 06:15 PM
swizz977
16
Aug 26, 2010 03:30 PM
99lx
Aug 21, 2010 09:57 AM
runawaylegalsec
Apr 19, 2006 09:19 AM
