97 civic hx.... oxygen sensor problem
Old Feb 24, 2012 | 02:01 PM
jdemon989's Avatar
Default 97 civic hx.... oxygen sensor problem
i got a 97 hx and been working on it for about 3 months. now it run and havent had a problem with it but doing a tune up and found that the oxygen sensors are switched. the primary/a.f meter is in the secondary spot and vice versa. the primary is somewhere around 300.00 dollars and the secondary is 75.00. so i thought they switched them to save money oh the primary/a.f meter IS NOT plugged in but the secondary one is. it also has a cheap *** header on it which was on it when i bought it(got a new one) can the car run and run good without the primary/a.f meter plugged in? and help from all the honda gurus out there would be great.
Old Feb 25, 2012 | 05:45 AM
Is your car 5 speed?
Did the previous owner convert the exhaust system properly? I will assume no. Here is a link going into detail about it more.
https://www.hondacivicforum.com/foru...version-73237/
The primary o2 sensor is not plugged in since the HX has a 5 wire o2 sensor ($300) and the 4 wire that is in there will not plug up. The o2 sensor was put in there to stop an exhaust leak.
Old Feb 25, 2012 | 07:40 AM
You need the primary sensor to run right. Without it it won't go into lean burn mode and you won't get the best mpg.
Old Feb 25, 2012 | 06:47 PM
jdemon989's Avatar
i just put a new exhaust on tonight and yea they didnt convert rite but i just did and i have to put the header with all new oxygen sensors primary and secondary so we will see what happens after the install. but it runs good with the secondary only. anyone think they could have rewired it somehow to make it work with only the secondary.my check engine light is on and went off when i did plug in the primary but the car idled wierd surging and almost dieing so i unplugged and it stopped surging and the light went back on. so i dont know.
00hondacivicsi
Jun 16, 2010 09:03 PM
Token21
May 20, 2010 10:57 AM
Myk
Sep 19, 2007 05:07 AM
punchodex
Nov 14, 2005 08:11 PM
Traumagas
Sep 24, 2005 05:31 PM
