97 EX Starting Problem
Old Dec 22, 2011 | 02:29 PM
popsicle's Avatar
Question 97 EX Starting Problem
Just recently I started having a problem starting my 97 EX that has 190,000 miles on it. The problem is that when I try to start the car the first time it will die (both cold and hot). I turn the key off and do the restart procedure again. Usually, this time the car starts. If it doesn't start, I do the restart procedure again and then it starts. After it starts the engine run flawlessly and nothing else seems to be a problem. I suspected it to be a fuel pressure problem and that the fuel pressure regulator was defective. However, after checking the fuel pressure with the engine running it was a nominal 43 psi with the vacuum line disconnected and plugged. When I reconnected the vacuum line the pressure dropped to a nominal 33 psi just as the manual requires. I have no error codes showing from the ECM. Now that everything checks out, I don't know where to look next. Has any one else had this problem and what was the cause and correction?
Old Dec 26, 2011 | 10:37 PM
mpklkj's Avatar
try reseting your ECM by disconnecting the negitive cable for 45 seconds then hook up and start again.
djt
Jun 21, 2008 07:48 AM
totenkopf
May 31, 2007 03:36 PM
Expando1
Aug 12, 2005 08:34 PM
terraeisa
Jul 14, 2004 10:23 PM
raphn
Jun 14, 2004 02:07 PM
