97 SI AC problem
Old Aug 24, 2010 | 06:02 PM
jpinperth's Avatar
Question 97 SI AC problem
Hi,
I'm having a real problem with my AC. I've had it in at the dealership for weeks and there is still no resolution. They have done everything possible to get the AC to work right but it blows anywhere from 13c to just over 20c. I am su****ious that it might have something to do with maybe the hot/cold lever. Is it possible that warm air is bleeding into the system, and not allowing the temp to get cold? If anyone has had a similar problem and mayb suggest a solution, I would be grateful.
Thanks
JP
Old Aug 24, 2010 | 07:40 PM
Put clamps on the heater hoses (or even better, reroute hoses and bypass the heater core entirely) and test drive. Could be a problem with the heater shutoff valve controlled by the hot / cold lever. Also drive for a while and check how cold the suction line under the hood (from firewall back to compressor) gets. The air at the vents should be approximately the same temperature.
Old Aug 25, 2010 | 01:45 AM
jpinperth's Avatar
Thanks, I'm going to suggest it to the mechanic.
Slammed98silvercoupe
14
Dec 19, 2010 05:16 PM
djt
Jun 21, 2008 07:48 AM
redlines4us
Aug 22, 2006 05:49 AM
tanksOnFire
Jan 8, 2005 03:38 PM
tanksOnFire
